- Jul 22, 2020
- 333
- 674
- Etrusco T6900
- changing a load of things again
If it's a 3 way fridge there is no chance it take only 55W when running on 240 volt. It's likely to something around 200W.dometic 3 way it only draws 55w so would be fine for 30hrs
Do you normally run it on the inverter ? Have you checked it will run for 30 hrs with no solar top up? I personally would not like to leave it on and risk battery discharge. As Badknee said, closed up, chilled contents will still be chilled if you add something frozen like blocks or pre-frozen bottles of water.dometic 3 way it only draws 55w so would be fine for 30hrs
your leisure battery or batteries may well be exhausted long before you get to Santander if you run your 3 way fridge via an inverterdometic 3 way it only draws 55w so would be fine for 30hrs
i have a switch over from shore to inverter.
That’s probably a good idea but only in the dark. ……i have a switch over from shore to inverter. and my leisure is 300ah lithium, i shall do a test this week,
Oops writing at same time!I would have thought that would only power your 240v sockets rather than your fridge as well.
the hook up and inverter go into 32A 2 Pole 3 Position Changeover SwitchThat’s probably a good idea but only in the dark. ……
So your switch over comes before the fridge electrics and doesn’t just power your sockets?
i have turned off the charger in the sargent so only supply van no loopI think the problem usually is that if it really simply switches so that the inverter powers everything, then the inverter will be powering the battery charger, which will be charging the batteries, which are powering the inverter...
However I have a similar arrangement - all loads powered by the inverter - but the inverter and charger are combined in one unit, so that loop doesn't happen. I think 300Ah is a bit marginal for a Santander crossing, but I suppose if the power runs out after 20 hours that's better than switching off right at the start of the crossing.
Did you cover your solar panels or disconnect them before measuring?as i said just seeing what the art of poss is. its drawing 9.9amps. and as two on tour correctly said 132 w. (not sure where i saw 55)
how long will 300Ah lith last
View attachment 672874View attachment 672875View attachment 672876
Probably spot onIf it's a 3 way fridge there is no chance it take only 55W when running on 240 volt. It's likely to something around 200W.
But as already mentioned you should be fine if you chill down before the journey and add some frozen stuff like milk.
no just went and made sure the numbers were as i remembered, but i was way out on the wattsThe OP has so much more information about his system than he divulged in that first teaser of a post! - still it has proved interesting.
what i should have said in the first one was is it against any rules /lawsno just went and made sure the numbers were as i remembered, but i was way out on the watts
i will check at 10pm tomorrow night and see ( yes i will peep after work first)
ok thanks, freeze some milk thenYour fridge will be running switching via the thermostat so will probably be on for 50 to 75% of the time it will depend on how hot is is on the car deck.
So at 75% you will have taken 222 ah out of your batteries. By the time you have boarded and disembarked and allowing an hour or two sails time variations, you will probably have a totally flat battery and Lithium's really don't like.
Running on gas is electric is fine.what i should have said in the first one was is it against any rules /laws
how do i tell the fridge the engine is running lolRunning on gas is electric is fine.
Have you tried it on 12v smaller wattage element but should be OK and no inverter loses so will draw a lot less power.
