- Jan 23, 2025
- 63
- 27
- Knaus Van i 550 MD
Evening all.
Nearly there with my lithium battery & chargers but just had a few last questions for those in the know.
I've fitted the Victron Orion 50a b2b between the starter battery and the leisure battery with 16mm2 cable which is about 1.2m long.
I've just started the van and at tickover it's only producing around 21a into the b2b. Is this normal and will it increase once being driven?
Next question
... How do I keep my 3 way dometic fridge on 12v power? It's not got an auto option but when I choose 12v, it does the normal beeping to warn the engine's not running. Can I force this to run on 12v (I know it will pull around 10a). Is there something I can do at the EBL end so it stops complaining and just works?
Lastly, I'm going to install the Victron 30a mains charger tomorrow. I know I need to pull the fuse from the front on the EBL to disable the existing mains charging but can I just connect the pos/neg to the back of the EBL which goes to the leisure battery?
Cheers all for advice/help
Next question
