Fridge induced floor problem (1 Viewer)
Aug 9, 2011
321
2,032
Broadway
Aclass
since 2009
Had a few packs of ice cubes in the freezer compartment. At some stage the power was disconnected and the cubes melted. Discovered this as noticed water running across the floor and into the floor hatch. It appears that the hatch has expanded with the moisture and can no longer be opened. Any hints on what to do appreciated.
Dec 12, 2010
5,572
23,074
Cumbria
since 2011
How on earth can they build a floor in a kitchen area that isn't waterproof ?
Jun 26, 2018
1,100
5,849
North West
Florium Wincester
Europe & USA since April '21
Dehumidifier, electric or powder may also help. Heat can make the wood expand. So I'd let it dry as naturally as possible.
JockandRita
11,913
159,275
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Why didn't they match the pattern? My OCD would be on overload with that mis-match!! :eek:
Have a look at the pattern. When they eventually get it out and rotate it by 180 x degrees, it'll match. ;)
Cheers,
Jock. :)
WESTY66
6,765
17,507
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
Cheers,
Jock. :)
Fwiw jock I think the lid is 180 deg out also, regardless of wood match, the handle should be nearest the doorđź‘Ť
Jun 3, 2021
330
264
Hymer B680
Is there another floor hatch nearby that you can remove and reach under to push the lid up, also the patern should match, I can see that if you turn it round it still wont match which makes me think that has it been swopped with another one the same size.
Bobbejaan
Visiting Coventry
Jan 21, 2014
132
449
Middle-Of-Nowhere, Scotland
Tardis-Too
Just kidding. It will shrink when it dries as anyone who has owned a wooden boat will tell you
Tony
Of course it will shrink ..... The Ark was originally designed to allow for FOUR of each animal to allow for spares ...... But they discovered a design flaw when it started raining and then had to limit it to just TWO of each. :LOL: ..... And they still didn't have enough room for the Unicorns.
Oct 30, 2016
1,596
3,238
Colchester
Le voyageur 8.5
On 3rd van so not a total newbie....
If it doesn't free up when it dries, can you access from an external locker to put some pressure on from below?
Themselves
Aug 9, 2011
321
2,032
Broadway
Aclass
since 2009
Many thanks for the advice. I may have been misled by the water on the floor. I managed to remove the hatch by firstly removing the little pop up lever and then knocking out the cover underneath. Inserted a L shaped steel bar and gave it a couple of sharp upward knocks. There was some strange looking guck that we believe is solidified bbq sauce. I do vaguely recall spilling some . Scraped it off and all is well. I regret, for those who care about such things, that the floor pattern does not align. Happily the wine store is now accessible and my evening is saved.
Oct 30, 2016
1,596
3,238
Colchester
Le voyageur 8.5
:giggle:
Thought it seemed strange, glad you got it sorted, the mismatched flooring must be a hymer?
