Fridge and trauma heating systems broken
Falmouth cornwall
Pilote p650
3 years
Pilote reference 650.. 06 plate. Does anyone know anyone that supplies spares... I know its an old van....
Hi its the circulating fan and the pcb board.. the problem is the fan keeps coming on all the time at will??
So the warm air blow fan runs at full chat continuously instead of slowing down after reaching set temperature ?
I'd look at the thermostat, usually positioned above the hab door.
Never heard of that, have you spoken to Truma ?
Well the engineer that has it they are saying new pcb and fan
Are you thinking maybe they're just chucking parts at it and hoping for the best ? Expensive parts too no doubt.
It's a tricky one, but if it gets your boiler working, then maybe worth it.
You might just have to suck it up.
You may get better results searching for Truma spares, it won't be as much of a trauma!
Hi, I couldn’t remove my PCB in the truma for testing so went directly to truma in Derby. They tested absolutely everything and replaced the board for me and it was around £375 inc vat. They take the unit out as well to ensure it’s all working as it should. If it happened to me again I would go direct because i was sick of the line “it could be this” and then having had a new fan and it wasn’t we were already £200 down.
Do you mean you had the whole unit out and sent it on?
Mine had an odd fault last time I used the heater because it wouldn't turn off. I switched off the main 12v switch on the ebl for a few seconds. Turned back on and OK. Yours may just need rebooting. The boiler has 12v even when the main switch on the panel is off likewise the fridge.
Oh dear I'm.in cornwall!
Don’t fancy a night in Derby maybe 😂 to be fair they send through a close by campsite referral when you book too but you may find a good engineer local that will be just as good.
Oh that's interesting because the electric block has to be replaced not working. S the plan is to fit new and see if the boiler decides to work
Would love to come to Derbyshire love it..found out the electric block isn't wring so hoping a ew one will make the boiler work.....here's hoping!!
