Fresh water tank fittings?
Brucie
Derbyshire
Coach built - Knaus
I’m a newbie
Hi there Funsters.
My Knaus MH has a threaded cap on the fresh water tank. Has anyone ever seen a hose type connector cap for this threaded type?
The ”universal” hose adapters do not fit this threaded type even though I have tried. I usually end up with wet trousers and shoes - which amuses my wife.
Thanks all
A photo would be good - there are so many different types and sizes.
  • Informative
Reactions: DJT
If it's a standard IBC thread, this will work.
Ibc tank Adapter Adaptor Connector Tap Hose Hoze Cap Water Bowser Standard Fit
£3.99
eBay
Link to above.
<Broken link removed>
If it’s the connection / tapping into the tank itself more than likely a bsp standard thread.
As said a photo would help answer your question.
Thanks all for your suggestions. Here is a couple of pics
That looks like an IBC thread. To confirm, the diameter should measure 2 inches.
If measuring confirms the above then the fitting in post #4 will allow you to connect a hose with a quick fit female fitting.
