Freezer door not sealing
Brassempouy, south west France
Hymer B878 SL
Since Feb 2020
The door on the freezer compartment of our tall 2016 Dometic fridge/freezer appears not to be sealing properly. When closed, there is a millimetre or so of gap around the door making it a 'rattle' fit. Has anyone had a similar problem or know where to get a replacement Dometic door seal?
If you post a picture I have several Dometic doors in my unit i plan to ebay
I've recently had a similar problem with Waeco / Dometic fridge. That turned out to be that the screws fixing the door hinges had worked lose enough for the door to be out of adjustment and it not locating with the top & bottom catches correctly. Not an easy fix as the main problem one was the bottom hinge bracket which is fixed with T20 Torx headed screws. Now all done and closing correctly.
