Ford wet belt issues (1 Viewer)
Jun 29, 2022
4
Kennyboy1
Hi Ladies ans Gwnts, im new to the forum, I am looking for aome guidance. Last week my transit came to difficulty and garage saod it is the timing belt has slipped. Its a 2018 custom with 77200 on the clock, has anyone had any issues sinilar or csn guide me through if this is covered under warranty?
H
Jun 29, 2022
4
Kennyboy1
Hi thanks for the reply, I rang them the other night and they have raised an issue for me, they said my particular model isn't under the recall situation but I have asked them to check what year the van was made rather then when it was registered? Just to be sure, I will be ringing them tonight when I am home to push a little harder as I need to get back to work.
Sep 17, 2017
6,204
11,815
Birmingham, UK
A-Class
Timing belt slipping and losing time is a serious issue. It normally means valves have been mashed by the pistons. Frequently, the whole engine is replaced because of the knock-on effects.
You've spotted that there was a recall on that engine for timing belt failure. I'm not sure if Ford have a web site where you feed in the VIN to find out if yours was affected?
H
Jun 29, 2022
4
Kennyboy1
Hi, I caed ford the other night and they said there is not a recall on my specific van ao I asked them to check what year it was made rather than what year it was registered but looks like a big out lay which is a utter heart break given how old the vehcile is
Jan 22, 2013
1,341
73,300
London SE
A class Adria vision I707
since 1971
Not your engine but Fiesta mk7 with the eco boost engine are referred to as Eco boom in the motor trade because
there wet belt system is so unreliable, and in the Eco Boost engine it drives the oil pump so when it slips you have a blown engine, totally stupid design IMO
PP Bear
8,292
31,404
Kent, UK
Auto Trail Dakota SE
I’ve had a belt go on me, were is stripped the teeth at the crankshaft, but never snapped. I was lucky that there was no damage done, as has already been mentioned, they can usually wright off an engine and be £1000’s to repaired or replace.
I don’t know about the warranty, but keep pushing ford over it.
Did you have the vehicle from new, if so has it been ford dealer serviced (not strictly a requirement, but strengthens the case) and at what mileage or age does the belt need replacement, as these can details can be used to strengthen your case.
Good luck.
H
Jun 29, 2022
4
Kennyboy1
I have only had it since January 2021, i believe they say to play safe every 120.van is sat on 77200 😮‍💨
PP Bear
8,292
31,404
Kent, UK
Having a read up on the system, it seems that while it’s quoted as 100,000 miles plus, or 10 years, it’s recommended to have them changed around 60,000 miles.
I do hope that ford come through for you, or you may end up forking out over this.
Some info here…
PP Bear
8,292
31,404
Kent, UK
Hover board, its the only way to be sure….
Sep 17, 2017
6,204
11,815
Birmingham, UK
A-Class
Cheap is the word, give me a chain or gears any day,
Gears last a long time, but are really inefficient and have lots of geometry constraints, so are rarely used.
Chains last about twice as long as belts. But it tends to be a more expensive job to replace them when they do need replacing. Especially when they get floppy and start chewing up the guides and casings and cause engine failure because there's shavings in the oil.
Overall, belts are generally pretty hardy and reliable and relatively easy to replace.
Apr 27, 2008
11,980
14,396
Eastbourne East Sussex
Hymer low profile
Since 1972
From a search on google, if engine is properly maintained a timing chain should last 80,000 to 300,000 miles. Most will last the life of the engine.
Also they dont usually break suddenly, just become noisy and rattle.
Sep 17, 2017
6,204
11,815
Birmingham, UK
A-Class
I suspect most vans only ever have their belts changed once before they are scrapped. And they rarely break if changed when recommended.
Dec 12, 2010
5,559
22,981
Cumbria
since 2011
I wonder what the belts are actually made of and who thought it was a good idea to run a laggy band through an oil bath ?
Sep 17, 2017
6,204
11,815
Birmingham, UK
A-Class
I guess it means less seals and gaskets that might leak... but yeah, most rubber type materials tend to swell and weaken when exposed to oil. Hopefully they thought of that and spec'd something that would cope.
Jan 22, 2013
1,341
73,300
London SE
since 1971
Totally understand the differences, but to replace a chain to a belt submerged in oil for cheapness and a very slight improvement in efficiency is a backwards step in so many ways,
a quality dry belt properly designed could comfortably pass 150,000 mile between replacement, but the bean counters shaving a few penny’s off each installation will get there way leaving the current owner a whopping bill at the end of it,
we should have a Lemon law similar to the US where many customers with the same problem can instigate a class
action against the manufacturer,
