Ford Injector and Wet Belt issues
Leyland
Chausson 640
If this allowed by admin can I ask if members who are on Facebook groups that have Motorhomes that use the Ford Chassis (mine is a Chausson and use the Ford Chassis for many of their Motorhomes). Many are having problems with fuel injectors and wet belt issues. A group has been set up to try and get numbers etc to bring to Fords attention.
Can I please ask for people to post the following link on their Facebook page:
Many Thanks
It is mostly confined to the engine as fitted into the Transit Mk8 is it not ?
I don't do Facebook but I had an injector failure last year. Luckily still in Ford warranty. The ford dealer completed the 21B30 recall whilst they had it in the workshop.
  • Informative
Reactions: f6c
Yes it is, it stretches over 4 to 5 years so people who have had issues with injector failure will be able to give good input on the page and admin on Facebook can collate facts to hopefully get a positive reply from Ford.
This is the info they are after in a questionnaire they are asking members to fill out. Some have had multiple failures. One guy is taking them to court in October.
If you are out of warranty they have been giving a gesture to some people which really is poor on a piece of equipment that is not fit for purpose.
Yes, my son just had to have his changed on his Focus. A nightmare job for the garage and expensive of course. At the same time the local Volvo dealer did mine for £560, which not too bad for main dealer prices
I’ve not seen anyone have it replaced for less than £1000 on a motorhome.
I should have made it clearer; the Volvo has a traditional cambelt so thus the price quoted. I did not dare ask my son how much it cost him………..
the belts shed fibres which blocks the oil pick up giving low oil pressure, if i had to have a wet belt engine it would get an oil change yearly and belt change at 5 years maximum/50000 miles maximum
Ford have reduced their spec from 100 000 miles or 10yrs down to 60 000 miles or 6yrs.
More and more manufacturers are switching to Ford. I wonder what the wet belt failure rate is on a Ford motorhome? I suspect it is quite low due to motorhomes doing a low annual milage and perhaps being serviced more often than your average delivery van. What I don’t understand is why there are reports of some wet belts failing at relatively low mileages but others have had belts changed at over 100k miles and have said that the original belt looked like new.
I think there’s a couple of things
  • Quality of oil. Some oils may damage the belt, if oil to the correct Ford spec is used every time, then the belt doesn’t deteriorate.
  • Correct service intervals, I’m sure the multiple cold starts, engines not getting up to temperature, etc have detrimental effects on oil quality. This is often the case with lower than average mileage vehicles used only for short journeys. Services (oil changes) get pushed back to 2 years, but the oil has deteriorated or was poor quality to start with.
As chatteris says, regular, maybe annual oil changes, using the correct oil, and used for journeys where the engine gets up to temperature. Then ensure engine is not switched off mid-DPF regeneration (excess diesel injection causing oil dilution), might reduce the risk of failure.
Someone I know has a wet-belt Ford which has done well over 100k miles on the original belt. He regularly drives long distances, and the van is well serviced.
I've had the wet belt replaced on my Ford car, i was told that the main cause of failure is using incorrect engine oil. I bought the car at 5 years old, so don't know what oil had been put in previously. When it is topped up with the wrong oil, over time the belt degrades.
Another issue with Ford wet-belts is the complexity and subsequent cost of replacing the belt on a 7+ year old vehicle. There are, I believe, quite a few specialist tools required, and it usually involves replacement of the belt cover, as well as the water pump and tensioner. If there is any concern about the belt deterioration, then the sump usually gets replaced too. The cover and sump are made of relatively flimsy metal and can easily be deformed, so if refitted, inevitably leak oil.
if the belt has deteriorated oil strainer and or oil pump will need cleaning or replacing my mate has seen a few with oil pressure problems caused by wet belt fibres
Hi from NZ.
We have a Ford Zefiro 696 purchased with a mere 11000k in 2021 on the clock and have had 3 injector failures to date up to 22000k with the latest yesterday on our way to a campsite. Luckily able to limp (mode) to local dealer. Is there a Ford forum / confirmed reason for this continuing to happen. I originally sourced info that injectors (had a bad batch from manufacturer Continental) and Ford were merely replacing by demand via failures.
(y)
& the sump. You'd be mad to refit a sump.they are made of metal ,so thin it deforms the same as the belt cover
worldwide this one. https://fordtransit.org/forum/
Many Thanks
I had a mk 6 under warranty with under 20K on it in 2008 and it needed 4 injectors. Ford did them.in the end but make it difficult. They authorised 2 injectors first, and then the other 2 as it was only 50% improved!
The main issue with the belts is that the injector fault saw loads of diesel being thrown into the cylinder and then on into the oil. The first issues were with the ecu asking for oil changes at very low intervals because the quality had been degraded (by the diesel.) Ford botched that with a software update at first. Fast forward and you've got diesel degraded and failing wet belts.
Ford Optimistic Repairs Delivered.
Mike.
Any advice as dealing with this issue right now .
19mths ago in Spain had to have 4 new injectors put in, van garaged for a week in Salamanca 🙄
21st Feb on way to NEC same thing happened again!!!
Garaged again but Ford say £1600 as out of warranty!!
I am in talks with Ford HO, injectors not fit for purpose so don’t think we should pay
Any thoughts 🤔
I had a dual mass fly wheel fail on a SMAX just out of warranty. The best Ford would do is offer to investigate at my cost. This would have cost nearly as much as my garage charged for fixing it (c. 1k). Mind you great car after that for years. My point is that Ford apparently don't give a sh*t about their reputation or have any flexibility regarding their warranty periods.
Just had my Transit wet timing belt changed. Changed water pump at same time as well as oil pump belt. £1881.
On top of that when I went to pick it up there was a fair bit of smoke on start up. Injectors checked and…..yes….4 injectors…..Ford quote £1771.
Ford are phoning me back but it’s out of warranty and I would need to get vehicle uplifted and taken to a Ford dealer….nearest one is 50 miles away. They won’t tell me any goodwill offered until Ford can examine. Tried to explain that a failed injector is pretty much a failed injector and given the known issues it isn’t viable to get a vehicle uplifted to another garage for them to examine and tell me what I already know if they arent willing to offer/tell me what, if any, goodwill payment they are willing to offer.
Was it smoking when it went in?
Hi Stoosal,
Can you tell me how old your Transit is and what the mileage was for the replacement please, and any feed back from the repairer to condition of belts etc .
All useful feedback for everyone. Im on 26k miles and its five years old this year, so in theory not due yet. Most the journeys have also been long distance, and touch wood no injector issues so far.
Thanks.
Good quality VW injectors from a parts supplier are around £230 each then money back on exchange old injector.
Not sure how easy it is to change the Ford ones.
I’ve heard Vauxhall ones are a pig.
Hasn’t been started for a while so gave a cough and bit of smoke when it started but appeared to be running fine. I am happy there is no issue with belt/timing and injector is likely cause.
Hi Stoosal,
Thanks.
2019 plate. Build date is pre Ford issue for alleged injector issues.
18k miles and only does long runs. Belt looked fine. I change oil annually and way before any Ford recommended mileage. Tends to sit for longish periods.
I thought long about changing belt given service/oil changes etc but it basically came down to do I want to have a belt go in the middle of France and all that goes with that. Injectors have always been at the back of my mind given regularity of reports of failure so I’d rather they went now than in France etc……but it’s big bill to have to swallow.
Spoke to Ford……basically I would need to transport vehicle at own cost to nearest dealer which is about 60 miles away before they would even consider discussing any goodwill payment. That dealer can’t even look at it til mid April!
