Folding table leg for C.I. Riviera 141 Lux.
BamBam
Wales, UK
PVC
I'm a newbie
I have recently purchased a 2002 Caravans International Riviera 141 Lux. But, the folding table leg is short and is propped up with a block of wood!
The leg is 665mm long, with the fold at 310mm. But, it is 80mm short. The previous owner used a 80mm block of wood to prop it up.
Does anyone know where i can get a leg of the correct length of 745mm? The fold needs to be at 310mm
I have checked Rainbow conversions. But, none of their legs match the length that i need.
Any help would be appreciated.
You could try Magnums website but you could look at fixing the wood to the underside of the table and then the leg would reach the floor.:D
Is it not possible to cut and fix a piece into the leg.
Or as said fix something onto the bottom of the leg, or even at the top.
I can't see what i need on Magnums site. The 800mm block is too big to screw to the underside of the table. Thanks anyway.
I will have a look to see if it's possible to fix something to the bottom of the leg. Thanks
Get a piece of wood same size as leg and rebate it to fit inside the leg. Then glue in place. All part of owning a MH that has been screwed together by craftsmen. You will possibly find it left the factory like it in the first place or someone has made the table higher so they could get their knees under it.
Thanks for the tip. If i can't buy one of the right size. I might have to do that. You're probably right about it being raised.
I know it is late but mine has a block at the top where it joins the table.
