OldAgeTravellers
Our two new Fogstar Drift 280’s with Victron XS B2B, have been fantastic for the last two months away but now we are only doing a few miles every few days we are getting a strange mismatch. The batteries are connected in parallel with identical length 25mm2 cables +ve to one battery and -ve to the other with identical cables between and a Victron BMV702 shunt in the -ve lead. The shunt has obviously not synced for a while and tonight I have a reading of 29% on the shunt, 52% on battery one with 14 cycles and 67% on battery two with 12 cycles. All are saying 13.2 volts Both were fitted together new with zero cycles.
I don’t understand how the batteries have different charge values and number of cycles, which do I believe. I have checked the terminals are tight and with the kettle on using a clamp meter each battery is supplying 35amps and the two together on the joint cable is supplying 70A.
Anybody else seen this sort of effect? I think Fogstar are members. Or perhaps somebody like RogerIvy or of course the godfather Lenny HB. Might be able to shed some light. As a disciple of Lenny I don’t really want to go onto a site for Electrical Hookup.
I did notice while driving today on the Venus OS display of the Pi-GX I was getting 54amps which would have been 50 from the XS and 4 from the solar panels. Then a couple of times on the bar in the battery shop part of the display that has D on the left and C on the right the right of the bar would go red then the amps would drop to zero for a few seconds. Perhaps the XS was overheating. I haven’t figured out what all of that display means yet.
So, any thoughts. Thanks for any replies.
