Flash 02 split charging?
jjbrunton
Chausson Flash 02
Hello,
We've recently purchased a Chausson Flash 02 which we are loving :)
Our problem with it currently is that it doesn't appear to charge the vehicle battery when on hookup, this has led to a flat battery so far which wasn't pleasant.
There is mixed information online as to whether it should split charge but I can't see anything fitted that would enable that to happen.
What would we need to fit to have the starter battery charged when we are hooked up to mains?
Thanks!
Simplest way is to just use a small battery charger for the cab battery when on 240v.
We've been using a small trickle charger plugged into a 3 pin socket but ideally, we'd like something permanently wired so it automatically charges when on the 240v.
A vanbitz battery master is designed to do just that with a trickle charge into the starter battery as the leisure battery is being charged with either 240v or solar if fitted, have a look at their website and it will explain what it does and how they are fitted. www.vanbitz.co.uk
