Does anyone have any suggestions for fixing wood battens to a garage wall in a motorhome? Here's the issue. We have a Burstener Lyseo 680g. I want to attach tie downs to the upper rear wall so I can fix bungee cords between top and bottom to hold chairs, tables in place. There's a box step that runs the length of the rear wall at the bottom ( i think it hides the cabling and rear housing for the rear light clusters) that is ideal for sitting the above mentioned items on. There is a lashing rail with eye bolts underneath, so I have somewhere to attach bungee cords at the bottom but Burstner unhelpfully do not provide a rail at the top of the rear wall. I thought about screwing tie downs direct to the rear wall but Burstner advise against it. I think it might be relatively thin (10mm or less) ply. I'm wondering if the best solution would be to glue a
wooden batten in place at the top and screw tie downs onto that? Has anyone done something similar. My biggest concern at the moment is whether the batten I have is going to offer enough material for the glue to stick to (its about 2" square).
