Need advice wiring replacement spark igniter to Smev OF311FGT oven.
Took the side cover, seems spark ignition does not work as igniter unit removed by previous owner. Wiring and switch are present, so ordered replacement igniter. Came labeled UBZ6(12). Unfortunately no wiring instructions. I have identified the negative and switched 12v positive wires and the two leads to the grill and oven igniter electrodes. It looks like the end two terminals labelled 1 and 2 are for the positive and negative feed but which is which, similarly there are six terminals labeled a to f, I assume I can connect the two electrode wires to any two of these.
