wuzzlewood
All,
I have a knackered Liesure battery, not sure if Bailey will replace it again under warranty and not sure if I would want one anyway!
I have had issues with smart alternator and lack of Bailey fitted B2B.
I have now fitted a Sterling BBS1230 B2B with combined MTTP solar controller. I have at present 100w solar panel.
I was thinking of doing the following in stages.
1 fit Fogstar 105ah battery immediately as I need a new Liesure battery NOW.
2 use it in the very short term with the Sterling unit as it has a lithium profile!
3 in a couple of months when the boss agrees the spend, fit more solar. Probably two more 100w panels in series as the Sterling unit is a max of 360w input.
4 lastly fit a new mains charger, leaving the old BCA one to act as a transformer when on hook up only! New charger, probably Victron will have a lithium profile.
5 fit an inverter to run the coffee maker, microwave and hair drier ( all only occasionally)!
Initiallly I will rely on the b2b charging the Fogstar plus I can switch on the BCA charger in an emergency. Not the optimum profile for maximum charge etc but good enough in the short term????
This way I keep the cost to manageable chunks and solve my immediate problem of a knackered Liesure battery!
