- Oct 21, 2019
- 320
- 349
- Carthago C-Tourer
- Begun travelling the road in our first van in 2013
I am wanting to fit a Nasa Clipper BM-1 battery monitor to our new C-Tourer van to be able to have a better insight into the 12v in/out goings-on and current battery states. Practical space to mount it is somewhat limited in the cabin sadly, so keeping it simple is proving challenging. The dashboard is out, as is pretty much everywhere in the front cab section. One place where it would work really well for us, however, is above the hab door, to the right of the Truma control panel. My question is, has anyone ever needed to mount something there, and how easy would it be to run a flex back down to the battery locker, which is, rather inconveniently, located on the other side of the vehicle. Does anyone know whether there is a conduit in place that would allow easy routing for the necessary wires to run down from above the hab door? I suspect getting across underneath the floor is manageable due to the double floor aspect, but I need to get the wires down from above the hab door panel first.
I have already temporarily wired it up inside the battery locker to check operational worthiness etc, but it's just not convenient having to go outside to open a locker to read a display meter whilst crouching down, hence why wanting to have it sited inside the habitation area. The display module needs a good 70mm behind it to accommodate the workings and mounting bracket etc (I think there's enough clearance above the hab door, but again, I need to remove one of the existing fitments to double-check that measurement). If it were to need to stay in the locker, then I intended to mount it onto an enclosure for neatness and then mount the enclosure itself inside the battery locker on the internal bench seat panel.
Looking for sage advice and guidance from the Funster Collective please.
