First time owner first silly question.
Max65
Bessacarr E460
Just purchased our first motorhome Bessacarr E460, I have got my head around most of the heating and water supplies but the one thing I have no idea what it's for is the small chrome disk next to the water filling point.
It is a 12v socket for connecting a Whale water pump, if you need to pump water out of a container.
Thanks I had an idea it would have something to do with the water supply, something else I will need to purchase.
I wouldn't bother with it unless you routinely parkup on a campsite for two weeks where your 300 yards from the water tap.
Most motorhomers move every few days and fill up / empty water on the way in or out of the campsite or aire.
Or use a watering can for emergency top up.
Water carriers and pumps are often used by caravaners as they seldom move but are bulky to store.
I suppose a lot will depend on how you use your motorhome.
I have one that I use quit often when there is no close tap however I fitted to an extension lead so I can use it anywhere around the van and it’s not outside for water to get into.
you can use a bucket or small bowser to collect water easily and pump it into your tank however there will be those that suggest a watering can “you pays your money and makes your choice”😊
It doesn't matter which you choose to do your vans storage will quickly fill with stuff you will never use.
We learnt quite quicky that the 10l water carrier we use in the kitchen as we don't drink from the tap equally doubles to fill the tank if needed.
Don't bother.....it probably won't work as the contact area gets heavily corroded.
Just stick a hose in the filler and turn on the tap.
If you need to fill on pitch instead of uprooting and driving to a tap just buy a large watering can.
Max65
_----------+-------------------------++
Very expensive!
WHALE Superfil Submersible 12v Water Pump Kit, White, One Size Amazon product ASIN B004XI2AYE
