FireAngel faulty?
Plymouth
Since 2013
Last evening while watching tv in the lounge I could hear beeping coming from the van parked on the drive.
Brought the unit indoors and replaced the batteries (hadn't looked up the code at that point) and put new batteries in the unit. As it was quite late by then we decided to leave the monitor indoors and check further in the morning. A short time after going to bed the thing was beeping again, so the batteries were removed.
After looking up the code (4 beeps) turned out it was the carbon monoxide alert. We had no gas appliances on in the van, everything has been off since our return home last Sunday, we have no naked flame appliances indoors so we suspect the unit is faulty, it was fitted 12 months ago when the van was new.
Anyone had these things play up like this, surely it is impossible that we have carbon monoxide levels high enough to detect in 2 different locations where there has been no naked flames.
TheBig1
Carbon monoxide alarms often detect a failing leisure battery before you can smell it
D
Plymouth
Since 2013
Thanks for that important advice, I thought carbon monoxide would only result from a naked flame not a failing battery, but it beeped again after being brought indoors, well away from the leisure battery
Swifter
Herefordshire, UK
Since 2019
Agreed . I found out when it went off in the middle of the night . Well worth checking to see if the leisure battery is warm .
Kent
Carthago T149
Since 2016
I fit quite a few smoke & carbon alarms through work and Fireangel have a high failiure rate, I will always fit Aiko when possible, out of 5 or 600 fitted I have had only 1 fail.
Ejaydee
Penzance in (usually) sunny Cornwall
Roller Team T 590
Since retiring
Hi Sue Devon Sue, that is spooky as the Fireangel on the van started chirping while I was away in Suffolk last week. The single chirp every 40 seconds suggested the battery had failed, although the whole unit was less than three months old. I bought a new battery but it continued to chirp incessantly so the battery was taken out. It is interesting what Roger S has said regarding the reliability of the product, in future I will be buying something different methinks!
Jam First (y)
