Finally picked up Dolly - our first motorhome
Andrew Goodall
After 2 weeks waiting we have picked up Dolly, our first motorhome. A very exciting and tiring weekend but it all seems have gone smoothly(-ish) - slight problem with satellite dish (mobilsat) but at least its now down albeit in slightly thew wrong position.
Everything seems to work ok and the solar panel is charging the batteries - we have filled up the gasit cylinders with LPG and cleaned and flushed out the water tanks/system with puriclean.
I couldn't seem to work out how to get a tv signal using the status aerial and I am not sure what direction I should be pointing it in? Not having TV was actually quite nice so its not a major issue at the moment.
The plan is to take Dolly off grid in the next couple of weeks to see if we can work everything without EHU (first site was had EHU and a CMC site).
Any other tips about what we should do first or learn about (apart from reading all the manuals and experimenting with buttons and switches)?
Andy
Try to get to an early meet. You will find lots of people only to happy to help.
It is quite likely the TV will not work, if a sat dish has been fitted that might have used the inputs and cables etc
Our 07 MH had analogue TV's still fitted that had no chance, it had a free view box under a locker, we have an aerial as well as sat dome but aerial no longer any use (y)
Of all the things not have a TV is the one I would pick (y) although I would also want to make it work :)
Have fun
Congratulations! :D
Try out off grid on a ehu site , but not plugged in , so if things dont work out you have an alternative. The other thing is when you are loaded up , get it weighed , axle 1 and 2 and total .
Hi-smiley.png Welcome
Reactions: SMB
Hi, get yourselves to a meet people like the funsters are usually only too glad to help newbies as there are so many things to know and learn about how your own van works read the tips on here you may find them invaluable .:)
drive out often so that you get used to handling....trip off to the sun...not that you have to go far at the moment......stop, set up, chairs out relax...enjoy:D
Just use it and try not to worry about all the things people will say you ought to
Have a look round and try to follow the leads and you might find a little box that you have to turn on for the receiver to work. Normally well hidden up high in a cupboard somewhere underneath the aerial. Make sure your 12v is on and push or twist a few buttons and see if a light comes on. Then try tuning in tv when the light is on. Worked for me !
Hello and congratulations on your new van , try everything with the EHU off and see what works , ( we still take the manuals!! For swapping the fridge to gas and had help from Funsters at a meet !!)
Did you re tune the TV to your area , on some of those aireal ' s they a little light I up in the cupboard on the booster( WHICH NEEDS TO BE SWITCHED ON ) , it usually glows red when not pointing in correct direction , then glows green when in the correct direction.
Hope this helps
Terry
