Filler cap advice (1 Viewer)
tkk
Jun 9, 2014
369
277
notts
Frankia i640
newbie but learning fast
Have had a slight filler cap mishap, result no usable cap, vehicle is a Fiat a class (frankia) 2019 reg but probably 2018 build. Fiat pro are at a loss to identify a lockable replacement and cant identify size of replacement even from their Fiat access. Any ideas of a temporary even if unlockable replacement (their price of £51 +vat seems a bit steep) while i get a lockable one?
TKK
Dec 24, 2014
9,871
51,844
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
Last time I was in Halfords they had a range of temp replacement caps.
Have you tried Googling for the right one - or eBay?
Lenny HB
55,856
162,948
On the coast in West Sussex
Carthago Compactline
Don't know about Frankie but the Hymer cap is the same as the water filling cap except it's black instead of Blue. If so should be easier to get a water cap.
Reactions: tkk
tkk
tkk
Jun 9, 2014
369
277
notts
Frankia i640
Hi,
Thanks for reply. Some e-bay 2006 0nwards say will not fit Platform vehicles, presumably incl MHs. Ill try Halfords for temp. Soln.
Lennie, that’s useful, It will at least let me measure the bayonet size (original now unmeasurable!)
Tkk
GPW
606
879
Cambridge UK
Globescout Plus
Slight to minor!
A plastic bag and a tyrap may be a temporary solution.
Oct 12, 2009
11,490
25,433
A Class N+B Arto 69GL
Since 2009
Can't help with replacement, but if original is lost then next time do what I do have the key on the same bunch as ignition key and leave it in the cap while filling then one cannot drive off without replacing it on the MH.
Geoff
tkk
tkk
Jun 9, 2014
369
277
notts
Frankia i640
Thanks all,
Got an e-bay one £16, that said compatible with 150bhp 2.3 but not “platform” vehicle. Not the same as original, less complex and bayonet is shorter, but fits and locks. Presumably tanks have a separate “breather system” to stop vacuum and aren’t dependent on anything in filler cap,
Tk
two
Aug 4, 2011
4,914
4,590
West Midlands
A-Class Fiat
Just go to a large filling station. They'll have a drawer-full of them and be only too pleased to get rid.
Jun 22, 2014
566
760
Great Totham
PVC
Since 2015
Just looked at mine and it don't look like a Fiat Ducato std filler cap. I reckon A class are different as Lenny says same as water filler only in black. Mine has one of the plastic lugs broken off hence this search.
weekenders
2,668
2,004
Leicestershire
15 years
We also need s fuel filler cap for our Rapido 2004 model, eBay only seem to have water caps, but it’s a 50 m size water ones are smaller
Jun 22, 2014
566
760
Great Totham
PVC
Since 2015
Here' mine with broken lug. I bought a black water one but the lugs are different length, shorter. Can't seem to source one.
TheBig1
Nov 27, 2011
17,851
44,358
should work
Jul 24, 2009
4,370
110,496
South Yorkshire
Since 1999
Is it behind a flap? The filler on our 2003 Frankia broke the neck and disappeared somewhere. Ours was a white surface mount and I found one on ebay but unfortunately can't remember where.
Rosemary1
1,427
4,152
Dumfries and Galloway
Rapido A class
1 year
Ha - did that once and went back to the filling station and asked them if it had been picked up - they laughed and gave me a huge box of hundreds of them:) mine didn’t SEEM to be there but I found one that fitted(y)
Latest car has cap which is attached to car but the leaving key in is a good idea
