Hi all, the fiat satnav multimedia unit in my 21 plate ducato is a real pia. It’s steadily got worse & now it’s practically unusable. What happens is every time power is interrupted the screen freezes. So if you make a stop en route the screen stops at the point you turn off ignition, obviously you don’t realise this until you restart your journey and are on your way. It then won’t turn off & most functions won’t work. As it’s auto, sometimes when you set your destination then select drive, the screen stays on reverse camera because you obviously have to go through reverse to select drive. In any case the screen remains stuck for the remainder of the journey.
My question is has anyone else had similar issues & can anyone recommend a replacement unit?
Fiat don’t want to know as it’s out of warranty.
Thanks in advance
Thanks in advance
