I've been meaning to do this for ages, but I finally got to a weighbridge today to try and get a more accurate calculation done for my tyre pressures.
This resulted in 1,600kg(F) and 1,260kg(R) in "Winterisation" condition (ie no water, equipment etc on board)
I've made allowance for all the additional weight we'd normally carry (ie Fresh & Heater Water, 2x persons, food/clothing/equipment etc) which I reckon would be no more than 400kg. Splitting this front & rear I end up with adjusted weights of 1,800kg(F) and 1,460kg(R).
Continental supplied me with the table below for the exact tyres (225/75 R16CP) I have on the vehicle.
Applying my (above) adjusted weights to this (and "rounding" upwards a bit) suggests I should be at 3.25bar(47psi) for Fronts and 3.00bar (44psi) for the rears. As I tend to work in PSI, rounding these up to 50psi (F) and 45psi (R) would seem about right.
HOWEVER, the advice from Swift is that tyre pressures should be as per the Fiat Ducato Owners Handbook:- this very clearly says for my exact camper tyre size that the pressure should be 5.5bar(80psi) all round!!??
This seems like a massive anomaly - can anyone tell me if I've missed something..........
Thanks!
Thanks!
