Fiat Ducato side light connection
lynnian
Chesterfield
Ace Genova
Since 2008
After a little bit of help . I have an Ace Genova 2005 on a Fiat Ducato ( Similar to Swift ) the 2 front passenger side marker lights have stopped working, 1 to the side of entrance step and the one high up on front above cab. Fuse ok bulbs ok and main side light ok. I am after the point where the cables are joined to the main Fiat loom as I think this is where the break is. The wire from the one near step disappears over a chassis under the fridge area. Difficult to trace the other one. Had the same trouble with the near side rear ,found all the joint corroded . Thanks in advance.
