No twin egr Ducato had sgw (made until sept 19) euro 6 no adblue. Dates are difficult with Motohomes as they can lay around in different places for 6 months or more. eg mine left factory November 2016 Left Rapido May2017 Registered March 2018. Multiecuscan the best you can get for a Ducato.Hi,
does anyone know if a late 2018 Ducato has an SGW on its OBD system. (Before I waste money on a scanner)
ta
RobinFrom what I've read it's unlikely on 2018, but no direct experienence. You would be able to read fault codes anyway, just not clear them (ours does have SGW - 71 plate and I can read codes)
Some vans had a separate secure gateway unit hidden behind the dash that could be bypassed. Apparently that setup didn't last long and changed again to the gateway being built in to the BCM. I went digging behind the dash on ours and failed to find the separate SGW module (but did find the mounting points for it).
cheers,
Robin
