Fiat Ducato - Replacing Glow Plugs (2 Viewers)
Nov 3, 2016
881
1,683
Derbyshire, UK
Bailey Autograph
Since 2016
So I have a flashing glow plug heater light for 10 seconds or so every now and then on a cold start. Research tells me its a possible failed Glow Plug. Also the odd failed start sometimes. Engine runs great when running etc.
A set of 4 from Euro Car Parts is £70. I know removing them is best with the engine hot etc. But they are potentially 11 years old if never replaced before and they are prone to shearing.
Has anyone DIY'd them there self or should I just take to a suitable mechanics? I do most stuff like that myself normally. Just never done glow plugs before. Usually Spark plugs.
Reactions: Les
Dec 12, 2010
5,583
23,147
Cumbria
since 2011
You can do a simple check on heater plugs if you disconnect the feed wire and then just compare the resistance of each one with a cheap multi meter, that will help in identifying the culprit ?
My pal specialises in removing seized injector and heater plugs (does them for Mercedes main dealer on Vitos and Sprinters mostly and has some fancy hydraulic pullers). None of the local garages will tackle it themselves, once they've snapped them off !
I would seek out a garage with a known track record of doing them and I would get genuine Bosch ones or OEM.
davidathomas42
Nov 3, 2016
881
1,683
Derbyshire, UK
Bailey Autograph
Since 2016
Thanks for the info. I have a multi meter. Guessing I can find a YouTube link on how to do that.
And I’m gonna hazard a guess that your mate lives no where near me ? Chesterfield
Reactions: Les
Dec 12, 2010
5,583
23,147
Cumbria
since 2011
Sorry davidathomas42, he's up at Carlisle, but hopefully you could maybe find someone closer to you ?
This is a simple vid on what to do, although I don't know what access is like on your engine ?
davidathomas42
Nov 3, 2016
881
1,683
Derbyshire, UK
Bailey Autograph
Since 2016
The van upped its game today. It now flashed on start up for 10 seconds and the display now says check glow plugs.
Going to have to get this booked in and sorted ASAP now
davidathomas42
Nov 3, 2016
881
1,683
Derbyshire, UK
Bailey Autograph
Since 2016
Update on this thread
I updated the dealer on the glow plug issue along with the other stuff thats causing me issues. It went in to a truck repair shop on Monday. They finally started work on it today and rang me to say the glow plugs were already spinning in the cylinder head when they tried to remove them.
So its ripping the head off and re-tapping it to take new plugs. Its not a cheap fix but the supplying dealers are picking up the tab with it been a failed item on handover.
Next in the auto gearbox fault. They could not replicate the failure yet so are going to look at that again once the head is sorted.
Then back to the dealer to fit a new board in the Truma to hope that finally fix's it.
wildhorse3143
4
Swift Bolero 680fb
Hi, I am in need of my 4 glow plugs being checked,replaced, please can you supply contact details of your friend in Carlisle. My email is [removed] many thanks. John
Feb 22, 2011
10,503
22,027
Newcastle under Lyme
Hymer B544 A Class
Since 2015
wildhorse3143 It's not a great idea to publicise your email address on an open forum, you might be able to edit your post if you wish.
The original poster has not been around lately so may not see your post, but others on here may be able to help,
Best thing would be to start a new thread asking for help
w2f
wildhorse3143
4
Swift Bolero 680fb
w2f
Figaro, I cannot see anywhere to edit it?
Jul 29, 2013
9,185
20,504
Salisbury
Hymer B678DL A class
since 2011
wildhorse3143 if you put @ before Jim it will send him a message saying you have mentioned him and he will then reply I expect?
Apr 20, 2022
732
1,426
Brighouse, UK
Autoquest 155 2016
Since 2020
I have a set of genuine Peugeot glow plugs for sale £50 delivered (mainland only) I bought them for our 2007 2.2 puma and never fitted them. Pig to do. Inlet manifold has to come off.
