Fiat Ducato Lower Dashboard Panel Trim Cover - right hand side, how to remove it ?
Apache Hi Line 634
Can anyone advise how to remove the above panel - it’s on the right hand side which has the small square panel which you can remove to access the fuses.
One screw above fuse box in little recessed area (screw on right), and the rest just pulls off, from memory.
Screw position marked in yellow. pull entire panel from both sides.
from memory, I think on my X250, there is another on the other side pointing downward on the left of picture.
Yes there is another on mine too, you can just see the hole for it in above picture…😎
Does that one just hold the cubby hole in position? Cant remember and i not going out side now.
