Adrian140974
The lights on our 2019 fiat ducato are rubbish, anyone know if they can be upgraded?
Thank youAdrian140974 You might find this thread helpful: https://www.motorhomefun.co.uk/forum/threads/headlight-led-conversion-automatic-mot-failure.273251/
As above... been debated on here in depth in past... short answer is yes you could fit led headlights....HOWEVER.... are they legal to retro fit...??????????Thank you
In theory but loads of us on here have fitted LED and we have passed the MOT. My last MOT was at a Fiat Profession garage and the van passed with LED's.Retro fitting LED's will mean a MOT fail
Have done a bit more digging and you are right some MOT testers will pass so long as the beam angle is correct. Most of the failures are probably becuase the beam angle is out.In theory but loads of us on here have fitted LED and we have passed the MOT. My last MOT was at a Fiat Profession garage and the van passed with LED's.
This thread is well worth a read.The lights on our 2019 fiat ducato are rubbish, anyone know if they can be upgraded?
My bro is a tester and he said if the beams as it should be most couldn't give a toss.Retro fitting LED's will mean a MOT fail
Can't see what can be different about the spring.You need a different spring clip to the H7 bulb, I got a pair on eBay.
It was on my A Vlas I had to take the headlamps out. With the H7 clip the LED's were all floppy needed a clip about 2mm higher. The clips I bought said they were for LED's.Can't see what can be different about the spring.
The manufacturer's said they could supply a different locking ring for mine if I took a photo of the base plate.
Less than 1½" between back of lamp and bulge of inner wing....I had to release and remove the halogen with long nose pliers.
Be near impossible to get a clear photo and even less chance of undoing the screws to remove the locking plate unless I removed the front of the car and headlamp unit.
I wanted them fitting then, not in 3 weeks when the part arrived from China......maybe.
Sent back to Amazon.
That's what I was hoping.I fitted Katur bulbs to my 2019 Ducato. By golly!
Its no longer dangerous to drive at over 30MPH in the dark
LED Headlight
A variety of headlights with different performances to meet the various needs of userskaturled.com
They look good - where did you get 'em?That's what I was hoping.
My night vision isnt the best and I have trouble seeing the verge in oncoming lights.
My solution was a couple of 5" X 2" LED spotlights set to illuminate the verge and white line.
Works a treat and doesn't dazzle oncoming vehicles.
Was it just a case of swapping bulbs or any other messing around? ThanksI fitted Katur bulbs to my 2019 Ducato. By golly!
LED Headlight
Oh and which ones please?Was it just a case of swapping bulbs or any other messing around? Thanks
I did it and don't regret it! Link in the video description to the bulbs.
StealawayThey look good - where did you get 'em?
Wired to the a separate switch?
Hi Paul, which ones did you fit.I didn’t take a chance on a fail so spent 10 mins swapping back to candles before the test and put the led’s back afterwards
