A bit of background first.
I've done 35k miles in 10 years, while the kids were young we were away most weekends but living in Cornwall we never had to drive far.
Every summer we have always done a big trip in Europe, except 21, due to COVID we tried Wales! We've crossed the Alps six times trying a different pass each occasion, and also gone over the Pyrenees twice.
Today I changed my front pads and discs, even though I had 7mm on the pads and the discs were in spec with just a slight lip. Apart from the slider pins on the driver's side not returning as well as they should have, nothing seemed untoward.
Until I got to removing drivers side brake pads!
As you can see there is quite a chunk missing, MOT brake test passed in December, less than 100 miles since then, and nothing to indicate that there was anything this wrong.
I am putting it down to possibly age or either a manufacturing defect or to the heat cycles from the mountain passes!? Anyone got any thoughts, or seen this before?
For those who are interested, brembo pads and discs were used to replace, £124 from Autodoc. I did have to reuse the spring clips as the ones supplied didn't fit around the new discs!
It took four hours, the hard part was removing the caliper carrier bolts and torquing them back up. Oh and trying to pop on the gators for the slider pins! I gave everything a good clean, used Lanoguard on the subframe and also renewed the track rod ends, febi bilstein £15 each from parts in motion. The gator on the near side had split, drivers side was not far off but they were both still free.
