Fiat ducato 3.0
tonyvillers
Somerset, UK
Bessacar E795
Temperature gauge on dash not moving off cold when engine is hot
Not even a hi or hello... Newbie here!!
Oh and Welcome to the mad House.👍👍
Sorry people ,I’m new to this …
Hello everyone 😂
Any ideas has to problem and how to sort it, only noticed it yesterday when gave it a run up m5 done 20 mile but gauge never moved .
The sender gauge is the most likely issue or the wire to it is damaged or unplugged. Have you checked under the bonnet recently? I was told about a guy locally had squirrel damage to the wiring in his van as it had nested under the bonnet and snacked on a lot of wire
Cheers Stealaway,
Changed that today , still no movement on gauge , heat coming through blowers when running .
Any other ideas ?
Be grateful
Cheers Stealaway,
Any other ideas ?
Be grateful
If you are brave enough I had to spray silicone onto all the gauges on my old 2004 van. You first need to take the clocks module out which is amazingly easy.
