Fiat Ducato 250x passenger side glove box removal
North Yorkshire
van conversion
Help please, I need to remove it to access the rearview camera lead that comes in through a grommet in the engine compartment.
I need to replace my Vision Plus lead that runs from "in there" through to the engine comartment down and under the van (cable tied thereto).
Have removed all the torx headed screws I can find/ but the passenger side lower glove box still seems pretty secure on the passenger door side.
David1
Sorry, cannot remember but it does come off. When I had a tracker fitted it was removed and again for providing power for camera and monitor. Bump
assuming you dont have a passenger air bag,
I believe you need to remove the curved lower piece that would sit above you legs when seated. that is screwed in the top and the side inside the central glove box. there are also some large push clips once all the screws are out. then you will have access under the box either to remove it or access the cable underneath.
Update......
I found the necessary wires through the top dah glove box and on loosening the coiled extra camera lead under the bonnet found the necessary slim connectors there and easily accessible.
So thanks for the advice above but glad the installers made this repair relatively straightforward.
David
