Fiat Ducato 2021 - Particulate matter sensor fault (3 Viewers)
Feb 14, 2021
4,231
9,546
Milton Keynes, UK
Burstner Lyseo 727G
3 years 30,000 miles UK and Europe.. Campsites and off Grid.
Got a engine warning light a while ago. Multiecuscan software says it's the Particulate matter sensor at fault. (Pa24 AE) I did have Fiat check it too and they said Nox sensor. Is that a different name for the same thing?
Also, there seems to be a big variation in price for replacements of for Nox sensors from £50 (ebay) to £350 (fiat) and lots in between.
Any experiences and advice on this issue?
Two on Tour
10,866
56,470
Elddis Autoquest 175
Since 2010
Particulate matter sensor and NOX sensor are the same thing, sort of.
In simple terms, particulate matter sensors control and diagnose emission systems, and accurately utilise DPF regeneration strategies. This helps to estimate soot amounts in the DPF, and triggers an OBD fault signal by detecting DPF failure resulting in excess PM emissions.
It would be a reasonable assumption that Fiat would shaft you on price.
