Fiat bessecarr control panel
Hereford
neil trumper
Can anybody help me please? I turned on my electric yesterday and all the black writing has completely faded. I have this model, many thanks Neil
If , as I suspect , that is a Sargent EC620 control panel there is a small button battery on the rear of it that may be worth replacing in case that is the problem .
That I is fantastic help, thank you
Checked on the site but still not clear on how to remove control panel without braking anything.
Any help appreciated.
neil1983 it seems that the battery behind the control could be just be for its clock , information about it is in section 4.4 of the EC600 power control system manual . Do you have this manual , if not , it can be downloaded from www.sargentltd.co.uk support section and contains information regarding your control panel and a possible reset method if needed .
That’s fantastic, I will download it now and try to reset my clock. Thank you for your help
When ours goes blank it’s always that the power control on the main unit under the seat has been switched off by mistake when we’ve put our fridge covers away. I’m sure you have probably checked this already, but worth a mention I thought.
