Is that on the way to the dump point? I have seen plenty leave their valve open and dribble after dumping even English
Ah I understand now just lazy then.No he’s sitting on the dump point and made no attempt to manoeuvre the van after he noticed it wasn’t going down the drain!
Black goes in the drive over along with the grey everywhere we have been, not cassette as that might get a bit messyDid they not park over the grey waste drain properly or was it blocked?, or did they just empty out on the car park?
If there are facilities, it a bit stupid not to use them properly, ah well its only water, would be worse if they had dumped the Black in the Grey which we have all seen happen before.
LES
I think you might get away with that Geoff, it was people leaving the valve open to fully drain the tank that I was referring toWe often dribble a little bit after shutting the valve because there is a flatish bit of pipe downstream of the valve, which sometimes does not dump over the dump point but does on a different camber or when cornering.
I cannot see any way to stop that.
Its OK to put "macerated/finely blended" Black down a grid I guess, but it would stick to your shoes a bit if it was forced through a grey waste grid from a cassette , thats probably why its left there for all to ponder and offer "advice" to the offender.Ah I understand now just lazy then.
