Fault P0268 Cylinder 3 injector Circuit high
TCG
Salford Priors
Autotrail Delaware
Hi, can anyone assist, twice my engine management light has come on and the van has gone into limp mode. The obd scanner shows above. any idea on the cause and hopeful repair.
thanks everyone in anticipation
Bristol
Weinsberg
A few years.
Short circuit on number 3 injector check the electrical connection is on tight. If you are lucky that will solve your problem is not likely you will need a replacement injector
  • Thanks
Reactions: TCG
How old is the van.
A while ago there was a problem with the injector harness being too short and pulling on the plug at the injector.
A new extended harness was the cure
TCG
TCG
Salford Priors
Autotrail Delaware
How old is the van.
Hi papajohn
2013
