Extra battery or Solar panel or both and which one first? (36 Viewers)
May 8, 2021
1,714
3,377
Bedford, UK
Bailey Autograph792F
Since June 2021
So, we don't often use ehu, we don't often stay anywhere more than 2 nights and then get a good charge on the LB while touring between stops, BUT, we stayed at a steam fair for 4 nights recently and plan to do that a bit more often in the future and the battery got down to 40% mainly due to charging the wifes mobility scooter battery.
So, looking for more of a "comfort buffer" to give us one less thing to worry about for longer off grid stays. Remembering this is mainly UK sunshine we're thinking of either a solar panel to match the current Truma 120watt already on the roof to harvest more daylight and keep the current 300ah Fogstar topped up, OR get another 300ah Foggy for more reserve?
Or do we go both and be done with it?
Oct 30, 2016
1,600
3,260
Colchester
Hymer BMC t789
On 4th van so not a total newbie....
So, after 4 days you still had 40%, or possibly another 2 days left? How much more do you think you will need?
If you still need more, possibly extra foldout panels for summer use, it battery for winter?
Terry
12,048
9,557
Lincolnshire
Can't remember ;)
You can waste a lot of money over specking what you don’t need. Another battery will cost £500 /600 plus you then may have to upgrade your charger etc, to charge your added battery
Another solar panel or two will only cost £75 / 150 👍 you say you did 4 days and still have 40%charge that’s close on half your capacity. Extra solar is the way forward for now😉
Lenny HB
56,270
165,610
On the coast in West Sussex
Carthago Compactline
You already have a decent size battery bigger than most.
You are lacking means to charge for 300ah of Lithium. Ideally you could do with another 200 Watts of solar.
What size B2B do you have as its probably worth increasing that.
suavecarve
8,407
42,746
Surrey/Hants
Dethleffs Trend A
July 09
Solar.
If you could take a screenshot of your input from your 120 watts over the past few days it will show you how many watts you harvested. (Victron app)
If you got another 120 watt panels you just double your harvest of the past 3 or 4 days and work out where your ample 300 ah lithium would be with that extra solar
Langtoftlad
9,258
159,969
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
If it's very occasional how about a fold out extra solar panel for the odd occasions?
I had a Dokio 300w foldable panel ready to go at that same show but didn't need it as the weather was quite bright...
But if you did choose to go down the foldable panel route, then remember Amazon Prime Day - 8/9th October. I got mine, currently priced at £250 for £185 special offer price in July
Mar 23, 2012
10,186
34,774
sleights
c class
I don't know if would even need to be that big if there was 40% left on the battery after 4 days an extra panel of say 100w over 4 days would have added a fair bit.
May 24, 2022
59
93
Converted VW Crafter
Unpopular opinion but I would say battery only because you say you usually only stay a few nights then drive on. Therefore the drive will charge the batteries back up quicker than solar would in my opinion. I've found solar is like a slow charger on most days. On really sunny days it's great but I've found my 400W solar never replaces what's used in the day. It's more money; however, I think it takes away the power anxiety and you don't have to rely on the weather.
Mar 23, 2012
10,186
34,774
sleights
c class
Just thinking about your pattern of use. If your longer stationary stays off grid are likely to be in what passes for the summer the solar would make more sense. If however you stay off grid for several days quite often in the winter it could make more sense to add the battery as well.
PaulC70
May 8, 2021
1,714
3,377
Bedford, UK
Since June 2021
So, just popped out and here's the screenshots etc.
So, in the last 4 days it looks like that one panels harvested enough to get to 57% only, to be fair weather heres been crap with little sun and 2 days in particular nothing but rain and thunder, if you've seen the national news of the A421 being turned into a river, that's 4 miles from me :-(
Anyway, it does indeed point to the need for more solar when relying only on that for charging and Im guessing that the current victron would indeed need an upgrade?
For those that have suggested a fold out, I'm reticent about that to be honest, especially if i want to use it off grid, I figure if I need more solar it may as well be fitted and be done?
Terry
12,048
9,557
Lincolnshire
Can't remember ;)
I’m pretty sure your Victron charge controller can take about 350 watts of solar so another 200 should be no problem ( from memory ) 😉
suavecarve
8,407
42,746
Surrey/Hants
Dethleffs Trend A
July 09
So last 5 days would have given you 40 extra amps (if you had an extra 120 solar) or further 13% of battery.
Us the weather that bad or are you parked in the shade ?
PaulC70
May 8, 2021
1,714
3,377
Bedford, UK
Since June 2021
Weathers been bad and completly overcast too for about a week, not seen any sun. Shade wise, i'd say its in shade from about 230pm where it's parked currently but i've little option on that.
Lee Fryer
707
6,984
Eastleigh
Coach built CI Carioca 15
Since June 2012
The advantage of a fold up panel is that you can move it about to keep in direct sun so havesting a lot more
bigtwin
5,730
11,004
Derby
Concorde
Since 2006
Are your batteries lead, or LiFePO4?
The latter charge up much more efficiently than lead. Lead self-regulates and doesn’t always use all that the solar can provide.
Ian
PaulC70
May 8, 2021
1,714
3,377
Bedford, UK
Since June 2021
Fogstar lithium.
Ian
Sep 5, 2024
60
69
In a tin box
Building a PVC
If there's budget / space for both then do both.
If not then it's a swings and roundabouts sort of a question.
The pessimistic version goes as follows:
No point adding more solar if it's not going to give you the extra capacity you want in poor weather (which is when you're likely to be spending more time inside the van consuming more power).
On the flip side, no point adding extra battery if you've got no way to top it up due to lack of solar.
However, the answer lies with knowledge only the OP has. These decisions are always about being honest with yourself about your use case.
An extra panel would have given you a nudge more power. Would that have been enough? If so, then a panel is probably your answer. If not, then you need more battery capacity, but work out if that extra capacity would be enough on it's own to see you though the 'static' time (it will charge as soon as you're moving)
I'd also consider how your existing panels are currently wired. If wired in series then the voltages combine so you need to look at the open circuit voltage (or OCV). This will typically be higher than 12v which can catch you out if you're not aware of it.
Your Victron 100/20 will take up to 100 volts and up to 20 amps.
If your combined OCV for a series setup exceeds 100 volts then you might need to wire the panels in parallel (which keeps the volts the same but combines the amps) - but again be careful you're not exceeding 20 amps or you might be buying a new MPPT controller...
