External Socket 240v - has anyone fitted an ehu cable socket?
MisterB
Essex
Adria 670 SLT
i fitted a standard 240v external socket last year, which we used to great effect, but i would prefer to change it now to accept an ehu lead with the waterproof connector. it MUST be the female end so no one attempts to connect up to an ehu supply and i would prefer it to be a flush mount, with flap. I dont want a socket etc in any of the lockers however good you think yours might be .....
what i have works for me, but i just want to make it a bit safer/shower proof. i know i can get a deep (and large) box that fits flush, that i can fit my standard uk plug in, but again, i dont want it that big, essentially i want the reverse of what a standard ehu connection looks like.
i am happy with swapping out/over the connections from a standard fitting if necessary ..
I’m in Spain at the moment but Googling 240v blue flush socket brings up quite a few choices.
thanks, ive been on google, ebay, amazon etc and i cant get what i want - it just doesnt seem to be available in the format i want it. i know its an unusual ask, its basically an external 240v outlet but in the ehu style connector. my current uk three pin one works really well, its just personal preference that i would prefer to be able to plug in a fly lead similar to that used by campers in tents that have several sockets attached to it.
i would basically be using my motorhome as the plug in point as you would connect up on site.
what ive got works, but i want to make it better. we cook outside using 240v appliances, george foreman, pizza oven, induction hob etc
thanks, its what i want BUT i dont want something like on the outside of my motorhome, im trying to find that sort of connector that fits neatly inside a flap. as i stated i am not averse to swapping out a male connection to fit a female connection like you have shown, but it must be behind a neat looking 'flap' that fits flush to the motorhome.
i can get a quite deep flush box but its rectangular and far too big for what i want, they are essentially a way to 'waterproof' a standard uk 3 pin plug
My point looks to have an internal part screwed into it. I would think it would be easy enough to switch male for female?
Put a regular 3 pin socket inside a locker.......as waterproof as it can be.
The external cable will sit ALONG the bottom of the door frame, not straight out at 90°, and the door WILL shut due to flexibility in the door seal.
I don't know if thus will work for you, but we also do some cooking outside on an electric griddle/pan/wok.
First EHU cable from site bollard to an in-line ip66 rated rcd unit. Male to Female connections.
Then 2nd cable from rcd unit to a 3 way splitter. Male to Female connections.
Then 3rd cable from 1 side of splitter to van EHU. Male to Female connections.
And finally a 4th cable from the remaining splitter port to a waterproof box and multiplug 3 pin extension to run the 240v appliances from plus outside lighting if needed , all for use within the awning, or outside if reasonable dry.
Works for me.
What you want is this ;
A 90º plug in cable to the schuko socket with a 2pin european/spanish adaptor on the backIP44 rated .
Then just make up a fly lead with a spanish 2pin plug on one end & multi 3pin sockets on the other.https://www.leroymerlin.es/producto...gn_id=176013&dclid=CK2otYqpgowDFcecJwIdIFs9PA
I have one but never seen one with a 3pin uk socket on.
I have one of these too, very useful, I plug in a 4 outlet socket, a garden heavy duty waterproof one......
Quite a few here
perfect other than the sat tv and 12v connections that i dont need .... i assume though that the intended use is exactly as i want, but in their case i think they are for using in an awning to a caravan. so they can have sat tv from a dish on the roof, or feed into the caravan from a portable sat dish.
i already have an external socket, but its a standard uk three pin socket, it works fine and does what i want it to do, but i just want to make it better
Just keep loading more and you may find what you need, there's some on magnum motorhome too
