- Oct 12, 2009
- 12,167
- 27,300
- A Class N+B Arto 69GL
- Since 2009
SCENARIO
Several relations visiting, MH chosen for our own 'spare bedroom'. First evening Truma blown air heating turned on pre-supper. All OK. Second evening Truma on 2000, charger on EHU working.
PROBLEM
About 2300+ return to MH, 2x85Ah L/A batteries down from 12.6v to 11v. EHU had disconnected.
ANALYSIS
I started first with EHU supply. Changed cable EHU supply and battery charging restored, RCDs not tripped, so that disconnection was separate IMO.
What damage to batteries at 11v?
I left batteries on charge for 48 hours with no load. Then left them at rest for 2 hours to dissipate residual charge on plates. Voltage read 12.6v at control panel (even with new batteries never reads more at panel and usually 0.1v higher at terminals.)
Next test is to load batteries. Most lights on, but not Truma fan in case fault is there. Load showing 2.5A discharge, maintained for 6 hours.
Left batteries at rest to recover for 12 hours. Batteries then show 12.4v., after 3 days they are down to 12.3v with no charge (EHU nor Solar)
QUESTIONS
1. Is it likely that the Truma fan without EHU charging could have drained the batteries from 12.6v to 11v in 3.5 hours? Should I be looking for another original problem, e.g. Truma fan motor?
2. Was a load of 2.5A for 6 hours sufficient to test whether there is permanent damage to the batteries or should I load them for longer and how long?
3. According to answers to above Qs my next test would be to activate the Truma heating and observe the discharge. The fuse had not blown so presumable not a dead short, but maybe a mechanical fault(bearing?) causing a higher drain on the batteries?
4. Is my analysis logic and testing correct so far?
I would welcome expert opinion and advice please, not speculation.
Geoff
PROBLEM
ANALYSIS
QUESTIONS
Geoff
