Louisesjpp
We're a week on the road heading from home in Spain for a long UK tour, and we've already run a gas bottle dry. This is all new to us, but we did expect a 15kg bottle to do longer than ten days.
Questions: we still have a full Spanish bottle which should get us to England. There we will have to buy an English bottle. Calor seem to seem 'calor' gas: is this butane or propane?
Where, near Newhaven, can I buy the right fittings to convert, the regulator and hoses?
The gas locker smells of gas. I can't hear any hissing, and I've brushed the joints with detergent and water to look for bubbles. I have not seen any but its a far from comprehensive test. Does the gas locker usually smell a bit?
The Truma cupboard is always hot. On eco hot water setting, the water is very hot. I'm wondering if a thermostat is down and this is causing excessive consumption.
The Dometic fridge freezer I'm sure uses a lot of gas. Is there any way to turn the freezer off, which we don't use?
With 280 watts of solar and 200Ah of lithium, would it be possible to switch to 12V on the fridge? In therms of pwoer consumption: I know I'll have to fiddle about with the wiring to make it happen.
