Hey folks,
I’m looking to swap out my 97Ah lead acid battery for lithium.
Context : it’s only a 06/19 registered van, but battery seems goosed. When we first viewed the van before buying the battery was completely flat (and had been sold to dealer 5 months prior). It was charged on second viewing, then flat on collection. We were off-grid recently and even with starting on full charge at home, then being out of the van most of the time and very light usage (water pump, occasional heat blower and charging two phones) plus some driving - it dropped below 10v abruptly after not quite two days. So, I reckon that’s at least 3 full discharges, probably more. We do intend to spend more time off-grid.
I have very limited space in my Nuevo, so probably talking about a single battery drop-in replacement. I’d obviously like to maximise capacity (within financial sanity).
We have an Sargent EC700 Power Control System (and PX300 charger) and the manual has this to say :
“For optimum performance and safety it is essential that only a proprietary brand LEISURE battery is used and it is suggested to select a battery from the NCC Verified Battery Scheme with a typical capacity of 75 to 120 Ah (Ampere / hours).” & “The PSU is configured to work with standard lead acid leisure batteries, and in most cases is also compatible with the latest range of Absorbed Glass Matt (AGM) batteries. The system is also suitable for Lithium batteries with built-in Battery Management Systems BMS).”
What I’m really not clear on is the implications if I drop in a battery greater than 120 Ah?
There’s also a section on Sargent help site about whether a B2B (or DC-DC as they call it) is needed, but all I’m seeing is an explanation of what it is, rather than a way to decide! (https://sargent.zohodesk.eu/portal/en/kb/articles/do-i-need-to-install-a-dc-dc-charger). Reading around, the implication seems to be that B2B might be required for older vans - so can I make the assumption that I won’t need this?
Many thanks in advance for any advice.
Heeb.
Heeb.
