Hi everyone. First post here (and there will be a few, as need guidance with a few issues ).
Control Panel (100 is the model). No power when used van at weekend. Nothing springing to life. Leisure battery has juice. When you plug van into mains, little green light comes on the panel to show it’s plugged in, but everything else dead.
I checked under, in the garage, and the unit on rhs (electronic battery charger) had the button out when it should be in, so pressed that back in. Checked fuse. Nothing.
As a back note, prior to this I’d had a garage do sealing around roof and they’d been running a hose all over to check for leaks. I’m thinking water might have got in somewhere.
I’m not technical proficient, and won’t have any clue if you put up an electrical diagram lol. Any thoughts on what might be going on, or what I could try?
(based in central Scotland. Also need recommendations for someone used/trusted to maybe look at van? )
