Eura mobil cbe panel problem
West Sussex, UK
euramobil
10 years
Hi,
Looks like the problem I have is common, display is flashing drinking water empty when it’s full, gas when it’s also full, leisure battery empty when it’s full .
Checked all fuses, checked cables to the amp meter sensor sender unit, all good I’m at a loss. Help please
No idea I'm afraid.
Is there a reset procedure in the manual?
Would be tempted to remove and unplug the panel leave for a couple of minutes then re connect. A bit like unplugging a pc to reset.
I do not know if panel should be switched off first
