- Dec 23, 2015
- 445
- 523
- Pilote Pacific P650GJ
- Over 6000 miles between 3 March to 26 September 2017.
The drain on our Pilote is a long way underneath the motorhome and is fine as long as there is a drive over waste disposal. Not long after we got it last year I rigged up a corrugated pond pipe to it, with a short section which stayed in situ held by a spring clip screwed to the underside. I then had two extra (different) lengths which meant I would be able to empty regardless of where the grey water drain was, or throw it into a hedge if that's what the site owner asked. However, the pipes leaked at the joins and it wasn't very successful.
I now want to put a rigid pipe from the waste tank, using a right angled elbow joint and bring it to the edge of the motorhome. I would also like to put a waste tap on the end of the pipe, but this is where my problem is. The connector from the tank is 40mm, so I can use 40mm pipe and elbow, but the taps are 28mm so I need a 40mm to 28mm pipe reducer and I can't find anything online. I have posted pictures of the tank connector and the type of tap I want. Can anyone help, or suggest another way of doing it? Many thanks.
