Elsan (Pink) Toilet Rinse Fluid
Chipping Norton
Carthago-Malibu T460
Since 2015
Anybody interested in taking some Elsan Double Rinse (pink fluid) off my hands (no pun intended).
I have one full 2 Litre bottle of it + one partially used bottle. No longer needed, as new van flushes off clean water tank.
FREE (or contribution towards some Blue Fluid) to anyone in Cheltenham area. Otherwise maybe going to Malvern.
Our new 'van uses the same technique, however, I put a dilute 'Pink Flush' mix in a spray bottle and give a quick squirt after each use....
Do you put this straight into the cassette?if so yes and I'm in Cheltenham tomorrow ?
You could always mix some up and use it in a little spray bottle to spray around the toilet after flushing.
Hi matt34,
No, the pink fluid goes in a header tank used on certain motorhomes for flushing the loo. The fluid used in the cassette is generally blue.
Hi Ivory55,
Yes already do that, but the dilution needed means it will last for years............!
Hi @ian4apenny happy to give you a couple of quid donation for your pink flush fluid. See you at malvern
