Electricity problem in residential part
Hymer B564 from 1996
I need electrical diagram (better in English) for Hymer B564 from 1996
Problem kreis 2 (short circuit)
There is a manual in the resources section which says from 2000 but someone has reported that it relates to earlier models.
<Broken link removed>
I believe that is a 10 amp lighting circuit
What EBL do you have ?
It may be better just to trace the wiring checking insulation, connections and appliances
Kreis 1 and 2 are general circuits that usually have the lighting on them, but also other things like the fridge control and heater control etc. If it's a short-circuit, one possibility is a lamp failed short. Especially if the lamps are tungsten-halogen not LED.
If you are tracing the wires, maybe the main wire from the EBL goes to a distribution block somewhere - on mine there is one down in the cupboard with the Truma heater. It's one of those multi-way push-on spade terminal blocks.
