Did a search but couldn’t find the same issue and a resolution but today when starting the Moho with the step still extended, the buzzer sounded but the switch on the dash failed to retract the step, the switch at the hab door is working with no issue extending or retracting just seems to be the dash mounted switch that’s an issue. This is on a 2021 compact line I143, is there a fuse just for the dash switch ?
Also I noticed the cab battery only ever getting to around 75% charge showing on the control panel, I guess this would point to the cab battery needing replacing ?
Only had the Moho a week so could be operator error !
Cheers for any help
Cheers for any help
