Bump???Fuse? Bump if not!
taken them all out one by one. No evidence of any blown, changed the hubbert one 20 amp twice no change. Think there may be a short somewhere. as some strange things happen when the main control switch for power is off, like a residual momentary charge with lights briefly flickering, when lights are turned on and main switch is off. Very strange.You do need to remove to properly check, I once used a multi meter set on continuity , didn’t pick up a blown fuse till pulled out, wasn’t visually obvious even when removed
Thanks, good idea!Bump is to bump your thread back onto the front page, so that others might see it! Lots of people only read What’s New!
Yes thanks, wish I could find the motor!I am not very technical , but I would be looking to see if there is power at the motor , if there is and it’s not working that is the most likely problem
Doesn’t even mention it in the user manual!
Thanks,I would think it must be attached to the bed , but I guess if you can’t move the bed it’s going to be hard to find let alone get at
Edit - just googled the model, can you access under the bed from the garage or dies the mattress lift for access?
