The latest problems are the fridge is draining battery when traveling and the 240 lead inside m/h is burning where it plugs into a type of junction box (flat oblong plate where all240 wires plug into) it does not have a consumer unit like British m/hs the multi plug behind fridge I found was also burning the last time it was back in ( may) this year they renewed leisure battery and solar regulator also checked all wiring problem free for2 weeks I wishYou really need to describe the issues you have had so folks can advise.
One possibility where the fridge could drain the leisure battery is if the power from the alternator is not getting through to the 12V distribution box when the engine is running. Maybe a blown fuse or bad connection. If it's never worked properly from new, it could be a wiring mistake in manufacture. The fridge could be automatically switching to 12V mode, but the only power it can get is from the leisure battery. The alternator is supposed to power the fridge and also charge the leisure battery, when the engine is running.The latest problems are the fridge is draining battery when traveling and the 240 lead inside m/h is burning where it plugs into a type of junction box (flat oblong plate where all240 wires plug into) it does not have a consumer unit like British m/hs the multi plug behind fridge I found was also burning
