Elddis Autoquest Wiring Diagrams (1 Viewer)
Two on Tour
10,858
56,385
Elddis Autoquest 175
Since 2010
Has anyone been able to track down a wiring diagram for an Elddis Autoquest 155 2015 model? I have. number of habitation electrical issues with the van.
I have the Autoquest wiring diagram in the owner's manual but the wiring diagram is generic and not specific to individual models in the range, what problems do you have?
Two on Tour
10,858
56,385
Since 2010
loss of the meter showing a voltage/water level. no power to the water pump
Did you want me to do a scan of the wiring from my owners manual, normally wiring colours remain the same from model to model.
Do you have the BCA PDU (power distribution unit) fitted to your van?
Ian Bosman
Mar 14, 2019
1,137
1,132
Sutton Coldfield but East Yorkshire man at heart
Elddis Autoquest155
Since 2018
yes i have that module fitted. the whole hab electrics appears to be from Whale but a scanned image may help me sort out the issue
Two on Tour
10,858
56,385
Since 2010
The printing is pretty poor in the manual, so this is the best I can do you. If you need more detail of any specific areas of the diagram let me know and I'll see what I can do.
I can't load a large image because it exceeds the file size limit of the forum, but if you PM me with your email address then I can send you a larger image.
This is the BCA PDU schematic that I got from the BCA tech department.
Elddis Autoquest 196
Hi there,
I'm struggling with rewiring my autoquest.
There are 4x MCBs on the BCA PDU but to the rear of the unit there are five 230v outputs.
There are only four mains outputs referenced on the elddis electrical drawing!
Does anyone happen to know what output is what?
Thanks either way!
Two on Tour
10,858
56,385
Since 2010
Hi there,
Thanks either way!
Hi and welcome onboard, do you have an electric ring on your cooker hob ?
