Elddis auto quest 185
Just looking
I am a newbie
Hi, I am thinking of buying an Elddis auto quest 185 2018 model and looking for any information on what i should look out.
Make sure the travel seats are present - a fairly common trick is to remove them to gain payload. The usual damp checks gas and electric, sink drainage.
Damp at the back under the bed. The mastic on the plastic trims on the outside running around the bottom of the van cracks, water then runs down and penetrates upwards on the panels via capillary attraction. Damp meter is needed or at this time of year see if its soft using your fingers. The van will be out of manufactures warranty as you will probably be the second or third owner.
