Ecoflow Delta 2 Efficiency
British West Hartlepool
Swift Kontiki 884
Since 2017
Hi Funsters,
I purchased a Delta 2 as a back up battery, I dont need to go into why, or it would have been cheaper to go Lithium etc... it just works for me. Here is my findings
I depleted my 2 x 100a/h lead acid to the below SOC, these are brand new and came with the motorhome so I was reluctant to throw them away and start again.
I then plugged in the Delta to the EHU, I am fully aware this is inefficient but this was my first trial run.
I believe the Delta 2 has a 85a/h battery, though they only list is as 1024w/hr. I was expecting around 70a/h with losses to efficiency, but based on this I only achieved around 48 a/hr from the Delta till discharged. 20% increase in SOC though which was why I bought it and if you find a pub or coffee shop with permission from the owner in around an hour im good to charge again.
So to the knowledge base out there, is 48a/h as good as it will get based on losses on the Delta and losses on my on board charger OR is it worth connecting a dedicated battery charger to my lead acids and plugging the Delta into that?
Overall, it kind of does what I wanted, I just hoped it would be more efficient.
I can see I've opened myself up here for a barrage of abuse on why didn't I install Lithium but it keeps the keyboard warriors busy
Nidge
I have done the same. Its not efficient but that's not really the point. You have put some charge in your batteries which is the main thing.
Stepping up voltage with an inverter and down again with a charger is never going to be efficient but you have probably saved your batteries from overdischarging.
