- Oct 24, 2023
- 58
- 32
- Carado i338
- Caravan since 2014, Motorhome 2025
to those who've done this before, can I ask for a sanity check please.
My EBL and WA121545 are wired as below, this is as per one of the standard schaudt schematics.
van came to me with a nackered lead acid, I have swapped it for a lithium.
in order to avoid the WA 121545 boosters 40A charge looping the through the B2B relay inside the EBL (having learned from others on here there is a risk of burnout) I propose to rewire as below... as far as I can tell, I just join the boosted output + to the leisure + (assume all done with appropriate cabling/fusing/terminals, its just the logic that I'm sanity checking). WA121545 takes care of isolating this from starter + whilst D+ is not active ?
side note I'll remove the D+ input from the EBL as it will no longer do anything. My fridge's D+ is through a separate standalone relay and its high current power feed is direct off the leisure.
thanks
Ian
thanks
Ian
